need certain parts
Well, now that its finally warm out side, its only like -4 now an days. i can start working on the car.
I need a new wheel arch liner, a new rim, i want to do HIDS, and a new sound system ONE with a cd player, should i buy the player from ebay, or just forget it, and the acm,does it have good sound quality.
The wheel arch liner, and rim are prority, the belt is fudged int he spare, and i need that asp.
Where on the rim, does it say its size.
Whee can i get these two parts for cheap.
Disco, do you just want to replace the stock wheel you had on there with another one? If that is the case there are a ton of remanufactured wheel places out there if you do a little searching. Should be pretty easy to find and probably less than $100 US.
Wheel arch, do a search of places that part out cars or Craigslist. Would thin that wouldn't be that hard to find used if you do some searching on the internet. Can get to be a pain in the **** sometimes, but it sure beats paying full price.
Received 3,915 Likes
Disco, most rims are not marked with their size. You can figure out the rim height by simply looking at your tires and if you look, your tires will say something like 225/45R17. The "R17" is saying that your rims are 17 inches in diameter. If you still have the stock rims, then let me know which diameter rim you have and we can go from there as the stock rims are more than likely 7" wide as I recall.
If you have something different, then what you will need to do is get the tire off of the rim and then measure the inside of the lips from side to side and see what they say. That will tell you the rim width. For the most part, rims are measured in english units, not metric. Go figure. One of the last things to still be english. As for rim height, the best thing is to look at the tire. But if in doubt, measure the rim at the bottom edge of the lip and measure the circumference of the rim, then using the diameter of a circle, you can work out the rim diameter that way.
Not the serpintine belt, then belt with in a tire, its fudged and completely messing with my sterring, which i had fixed a month ago.
naelley, does that work for canadains tooo?
http://www.wheels-and-rims.com/cgi-b...item1c10d93639
Scott B
10-24-2015 01:29 PM
