Need help
Need help
I got an 02 Jaguar X-Type 2.5 crashed the front of it change the radiator condenser n fan the car was running it overheated but did not blow the engine I ran errands through the day did about 5 stops it drove fine before coming home the next day when I was gonna start it the car did not want to crank or start I jump the relay r10 it cranks but does not turn over I am getting power to fuel pump I still have to get a fuel pressure tester Anti-Theft is not trip I have an OBD2 tester which the car does not want to read I have checked the codes on the car hidden menu but do not know how to read those can anybody help me out see what it is
Received 3,932 Likes
Rne0313, try this, get into the car and go about your normal starting routine. But, when you roll the key to the START position, pause for say 3-5 seconds in the RUN position before finally going to START. If the car starts, then you have a fuel pump that is starting to go.
The other possibility would be the jar of the accident moved around some sediment and your fuel filter now is dropping too much pressure. You may want to change that just to rule out a possibility.
https://www.jaguarforums.com/forum/x...ersion-197064/
here's the problem with stalk codes, they are there forever and can be very old, things that happened that are fixed or one off events. You really need to get an OBD reader (ELM) and pull the current code(s). Then use SEARCH in this forum as nearly every problem code had been discussed ad nauseum.
Andy94SC
03-19-2012 04:01 PM
