need help asap (solved)
first off you'll need to get a scanner hooked in to read the codes, that will give you a starting point. Also does the message center display anything? Usually it will read what the fault is in generic terms, like DSC fault, or Cruise not available.
Next I'd check the engine compartment for a vacuum leak.
Received 3,886 Likes
Raga, remove the cover from off of the engine and you will see a hose about the same diameter as your thumb. Is this hose in one piece and not leaking/have any holes in it. If this hose fails, it causes all sorts of problems like you are seeing. After that, if the hose is good, then getting the codes read at a local auto parts store would be the next step so we atleast have an idea of what the car is not liking. From there we can give you a lot more detailed information.
Dumb/Luck (08-19-2011)
Raga, trust me on this one, pull the cover off of the engine, find the large hose that runs from the PCV valve to the intake manifold. You are going to find a rip in that hose. Replace the hose with either some 1/2" vacuum line or a new hose through Jag (costs $15 USD). For the moment, you can use some electrical tape to wrap around the hose to "seal" it back up until you can get a new hose. I just had this same issue.
You have a vacuum leak. In addition to the hose previously mentioned check the small hose between the brake booster and manifold also the IMT valves in the manifold looking from the passenger side the 2 round black things. Their O ring seals are known to leak.
1 Post
Received 9,006 Likes
Received 6,305 Likes
bydand
09-28-2015 09:47 AM
bydand
09-27-2015 12:00 PM
Collector1
09-26-2015 05:28 PM
