Need help finding engine number
My crankcase breather hose had fallen apart and the PCV valve should be replaced but when I look up the part for my 2002 X-Type 2.5 I discover that the part depends on my engine number. It seems that Jaguar made a mid-year change.
My problem is that I don't know where to locate this number. The manual says it "is stamped on an engine web on the right hand side of the cylinder block behind the engine mounting." I'm sure this is clear to some (many?) of you, but I don't know if I have to look down from the top, jack up the car and look up from the bottom, look from the front or one side or the other, remove parts to find it, etc.
Any help would be appreciated.
BrentGardner
28
04-26-2024 03:08 AM
