Need help finding part
and it hooks to some sensor on the other side. (or valve of some sort) I am failing emissions and I just recently replaced the IMT o-rings, the brake booster hose, and inspected the hose from the valve cover to the box. I am getting code P0174 and P0171. I did already search, but this is the last vacuum? line I have left. lol
FYI-- Look at he picture in the previous post-- see the two black connectors (motors) on the right side. thoughs are motors that run the TUNING TUBES that add 10 hp to the engine. There are "O" rings that dry out and leak tripping P0171/174 codes. Back out the bolts and TRY to pull them out, IF they come out easy they leak, I tweeked mine a bit and there ok, you can spray around them when running to see if they leak as pulling them out all the way might destroy the
"O" rings. There probably BAKELITE so don't pry to hard.
already replaced. The part I'm looking for is the fuel pressure regulator vacuum line I think... Part# C2S28870. Not 100% sure yet.
I talked to Jag and the hose you have circled is a PVC hoss ( not the big one in the front) $7.00. The FUEL PRESSURE REG HOSE they said is part of the plentum $755.00. That is why no picture shows it, if you flip the picture over(or who ever has it) it will show. For $755.00 I would some how find a way to replace a hose. or line or what ever it is. It's called reengineering for the benifit of you wallet. Someone on the forum might have a fix?
Good luck!
billbjork (01-26-2012)
Hi just email through exactly what you want and i will try to sort it out
we keep a few engines etc that are just for parts so shouldnt be a problem
jaguarxtypeparts@gmail.com
worldwide shipping on most parts no problem
hope this can help you out
The part # is C2S28870 the package is labled Hose-Vacuum I had the same problem the heat made it brittle and crumpled in my had too. $34
innzane
09-02-2015 10:08 AM
