need help identifying noise
I have an 05 3.0 Sport auto with 40k miles. I read through some of the propshaft threads but I'm not sure the noise I hear is the same, it isn't high pitched like others describe.
On cold days (sub freezing) I hear a whurring sound directly related to mph at low speeds until the car warms up. It sounds exactly like a worn speedometer cable from the old days. Revving the engine does nothing, it's only at low 10-20 mph and the pitch is directly related to mph. It sounds like it's coming through the firewall.
This is the first winter I've heard it and it goes away above freezing and after a few minutes driving. Thanks for any help.
I get the high pitched whine at higher speeds and the low pitched whurr at slow speed. I believe they are both from the prop shaft. They both go away after about 3 to 5 miles of driving. I can't say as I have ever tried to heat my car up all the way B4 driving off to see if the sound goes away.
Nice to see my 22 year old Buick with a little turbo V6 could keep up with some modern day Iron! Won't go around a curve like a Vette but the only turn I am concerned with is being FIRST onto the return road at the end of the 1/4 mile! LOL!
Could be propshaft related. Could be water pump, although less likely and probably would have sh*t the bed by now.
I would guess that it is likely the transfer case however. I had similar "whirr" and "grind" type noises and it was the case. Replaced.
Is your Buick a Grand National? I always wanted a GNX, although they are big bucks these days....
You can bet your boots its the propshaft, i went to great lengths to find this noise on mine and put up with it for 6 months untill it got worse you may find that it will start making the same noise above freezing as i did, I originaly thought the noise was comming from the air vents at first as it was so hard to pinpoint...mine made this noise at exactly 29.5 mph and at 12 mph, I tried all the greasing ideas without any improvement i then sprayed the propshaft rubber surround bush with silicon grease which srangley made the noise alter its frequency which to me gave the game away ...i was told it could be tyres /transfer box etc but i ruled out both as my X 04 reg had only covered 13000 mls so i took the gamble and paid for another prop to be fitted and there it was..problem now solved and it now runs like a gem (so quiet). For what its worth its not the bearing - its the rubber bushing that the bearing runs in.
And it is NOT serviceable. It's only replaceable, and that only by replacing the prop-shaft. (or cut-n-weld, but by the time you rebalance, whats the point?)
You seem to have similar issue as I have. I poured over the forums and came to conclusion that it was my drive shaft. Installed a new one(remanufactured from Jaguar). The noise is reduced(the high pitch noise is all but gone) but lower pitch(50, 40, 30mph) and the whirring sound(10mph) is still there. The noise are related to road speed, not engine.
It seems like the noise is coming through the firewall, maybe in front of console area. And at the peak(40 - 45mph) I can feel the vibration on the shifter knob(automatic transmission). So it looks like I'm back to the drawing board. It would be great to hear from the forum gurus.
baskervillema
10-01-2015 06:43 PM
bydand
09-28-2015 09:47 AM
bydand
09-27-2015 12:00 PM
