Need help with Jaguar Voice
As far as I know, you'll need the voice module and the mic to add Voice. In order to add bluetooth, you'll also need the bluetooth module and the phone module. You'll need the link lead to connect the fiber optics to the voice and phone modules. Then, the dealer will need to do the programming so the system recognizes the modules.
The modules are easy to install. Phone and Voice go in the trunk, on the left side. The mic goes in the overhead console and the bluetooth module goes in the floor console under/beside the storage compartment. All the connectors are there if your car is prewired.
I was going to do this to my 2005 but decided to trade before I installed the modules. I have everything you need if you are interested. The link lead I have is the one for adding voice and phone to the existing sat/nav. If you don't already have navigation, you'll need a different link lead. They are specific to the the modules you will actually have installed when you get done.
Let me know if I can help further and/or if you are interested in what I have available.
Thanks!
Dan
Thanks!
Dan
okstate734 (02-03-2012)
I have fitted both Jaguarvoice and bluetooth to my car, it was fairly straight forward to fit. You'll first to find out that you have the correct connectors in your boot. You'll need to lift the armrest to find a red/black connector and count the wires, needs to be 8 to be good to go for bluetooth antenna.
You'll need
Jaguarvoice module
Bluetooth antenna
Phone module
External microphone
d2b (fibre optic) connector
Took me 5 hours to install due to my car needing a new harness to be installed.
It cost me in total for parts, £150!
You'll need
Jaguarvoice module
Bluetooth antenna
Phone module
External microphone
okstate734 (02-12-2012)
