Need Help!!! turn indicators/AC/door locks won't work
Guest
Posts: n/a
Hi
can someone help. i tried a search, butdidn't find anything related to what's happening to my car.
i have an 03 x type and the door locks, turn indicators, horn, and dome lightstopped working. also, the air conditioner is not blowing air.
i noticed that when i turn off the car and remove the key, that there is a clicking sound underneath the dashboard just beneath the steering wheel. can it be related to my alarm system. the car starts fine. but the key alarm fob is not working either.
i checked the fuses underneath the dashboard and they are ok.
any help greatly appreciated
Jayz
Jayz
Guest
Posts: n/a
no work has been done on the car recently. also, when i turn off the engine the horn beeps when i pull out the ignition key and when i step on the brakes the clicking sound gets louder. the clicking sound is coming frome one of the relays in the fuse box under the dash. i swapped relays and the clicking is still there.
Guest
Posts: n/a
Its a relay and a fuse. Fuse in the passenger compartment controls lights, a/c. Fuse blows because relay under hood that controls
a/c compressor going bad. Relay 7 and fuse 99 I think on my 02, may be different on your 03.Need to check the diagram in the back
ofyour manual.May be other fuse too controlling the locks and horn.
FS[SouthEast]: GenRad GDS-510 scan tool
johnnie ryall
10-19-2015 09:44 PM
msdg137
09-16-2015 06:24 AM
Andrew McVey
16
08-27-2015 07:21 PM
SingBlueSilver
08-27-2015 02:20 PM
