need info on P1000 code, QUICK!
Old 06-29-2011, 12:24 PM
Adam Lueb's Avatar
Smile P1000
Originally Posted by porkenstein
This may not be allot of help but look at this thread. It's not a code you can clear yourself. It has to clear itself. I think there is a good chance the owner cleared out other codes. If that's the case you will have that code until it resets if everything is ok. https://www.jaguarforums.com/forum/g...asy-way-50358/
A tech posted this in that thread. After 16 yrs of teaching Ford OBDII drivability and the Xtype basically running Ford software. P1000 is a normaly occurs after the Dtcs are cleared. It does not indicate a fault but as in previous thread just means not all of the OBDII monitors have completed.
Mine has come on twice since I owned my X. After I stop and do whatever, I'll start the car up and it goes of. Ford says on the Chart the P1000 code means checks not over - run engine longer.
Steviedee1st
11-28-2023 06:32 PM
Jpav27
07-31-2022 06:43 AM
Shawn Svacha
02-06-2022 04:53 PM
joesoap
09-10-2015 01:09 AM
philwarner
09-02-2015 11:45 AM
Quick Reply: need info on P1000 code, QUICK!
