Need to replace Alternator help!
Old 01-08-2009, 03:17 PM
htkenan's Avatar
Default Need to replace Alternator help!
This is my first time replacing my bad alternator in my X Type 2.5. Anybody got a installation guide which parts to remove step by step till I get to the alternator? Anybody done this yet?
Old 01-08-2009, 06:22 PM
mohrd's Avatar
Default RE: Need to replace Alternator help!
Haven't done and wouldn't do it as I'm not skilled enough as I THINK you need to remove the A/C compressor as one of the first steps? Techs will be able to better advise. When I'm home I may have the steps on JTIS or Alldata and may PM you what Ihave if that will help.
Old 01-08-2009, 06:50 PM
ArmyJag's Avatar
pm Christo he can give you the link to the free factory jag manuals for your car.
Old 01-11-2009, 02:00 PM
Step1 discharge A/C, step 2 remove A/C compressor, easy after that. Are you sure it's the alternator? Common wiring issues with the wires running to the regulator, recommend double check. I've only installed one alternator for actual failure not related to collision damage. I've repaired wiring on another 100.
RoyLittle0
05-25-2023 02:38 AM
Forcedair1
05-14-2023 03:28 PM
cissdm
05-03-2016 06:02 AM
KarimPA
09-12-2015 08:15 AM
KarimPA
09-03-2015 07:32 PM
Quick Reply: Need to replace Alternator help!
