Need to replace light bulb in headlight
You should be able to twist the rear section off and remove the light and wiring assy...
________
EFFECTS OF PRILOSEC
________
EFFECTS OF PRILOSEC
I suppose with the tight engine comparment you'll have to a few things to actually get to the bulb. I looked at it last night and it's pretty tight in there...
________
LATINJANNE
________
LATINJANNE
i took out mine yesterday to put new bulbs in, its pretty simple once you figure out that there are clips holding the bulb in. open the plastic cap, and disconnect the wire form the bulb, and then theres a clip u need to remove. once thats done the bulb just falls loose and u can remove it.
hope this helps
hope this helps
Tony K
03-26-2024 01:53 PM
rudelover2
09-11-2015 08:53 PM
