New battery, new alternator, no charge.
...and I thought it was all over. But it's not. And I re-read the stuff I found. The alternator should only give the 18 volt charge on the overrun, and only if battery is down. It causes misfires and puts the EML on. So I checked with the supplier of the alternator and he sent me another one. So, today, I got back under the bonnet and did it all over again. The new alternator is a Visteon item, as fitted during build, so I thought, this time, it will be ok.
It is ok, all voltages as they should be. I'm getting 13.7volts after a few minutes, dropping to 12.6 after about 5 miles, so that's good. Only problem is that bl--dy battery light is on! I'm beginning to think there is a problem with the car now, either in the wiring or the ECU. Hope it's not the latter, but I'll get more info when I speak to the supplier. Going to have to phone him anyway to arrange to send the dodgy one back. I'll keep you all updated...
Jagalag (03-05-2024)
...and I thought it was all over. But it's not. And I re-read the stuff I found. The alternator should only give the 18 volt charge on the overrun, and only if battery is down... ...The new alternator is a Visteon item, as fitted during build,..
..It is ok, all voltages as they should be. I'm getting 13.7volts after a few minutes, dropping to 12.6 after about 5 miles, so that's good. Only problem is that bl--dy battery light is on! I'm beginning to think there is a problem with the car now, either in the wiring or the ECU. Hope it's not the latter, but I'll get more info when I speak to the supplier... ...I'll keep you all updated...
I am waiting for it to arrive before fitting, so don't yet know if it will cure it, but the old one certainly had indications of having gone bad (my post, that I hijacked, is quite lengthy: https://www.jaguarforums.com/forum/x...-lights-226903). I've been trying to read round the internet on it but oftentimes the actual solutions and outcomes don't get reported in the threads in the end.
Incidentally, mine has ('had', as I need to replace it as well) a calcium lead battery [Vetech Premium Excel 80A 720Ah] when I got it just over 2 years back
This time I've ordered a used one for eBay. Has anyone ever found a new OEM Denso regulator that works?
2006 OEM Alternator Alternative
Battery light, alternator
alternator info
Voltage Regulator Location?
Back to Subforum
View Next Unread
Key fob problems
Today's Posts
Currently Active Users (2)
dh53
X-Type ( X400 ) Today's Posts8
You're not going to believe this, but it burnt me already. when replacing the alternator also do the air conditioning compressor upgrade as it will be out.
Before replacing an alternator on an x-type run the car till it is warm, the longer the better as i did an hour ride.
Get a non contact thermometer and take the temperature of bot the positive and negative cables.
Are they around the same temperature?
If not replace the one that is to hot, probably the negative, While at it, put another negative cable from the engine to a frame mount then back to the battery if you can.
On my car the positive was about 134 degrees and the negative was 202 degrees.
No charging problems now, i have a spare alternator and ice cold air.
Good luck
Good luck
Get a non contact thermometer and take the temperature of bot the positive and negative cables. Are they around the same temperature?If not replace the one that is to hot, probably the negative, While at it, put another negative cable from the engine to a frame mount then back to the battery if you can.
Then I tested it again, turned on the front and rear heated windshields and blower on and the cable is cold. So far, the voltage is rock solid too, and higher than before. It settles to a nice 13.4V, and previously it was lower (sometimes much lower) than that.
jackking jag
04-26-2021 02:57 AM
Paulrwalkington
10-15-2017 12:57 AM
WTB[LowerAtlantic]: Battery Box Needed
hlgeorge
12-03-2016 01:43 PM
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
