New member hello all
A 2009 X-Type that needs both front drive-axles/constant-veloicty shafts replaced?
Greetings from "across the pond" Matt,
Why do they need to be replaced? What did the shop/dealer/____ give you as a reason why they need to be replaced?
Cheers,
BK
Drive shafts
I had a constant noise when driving and I assumed it was the bearings in the hub/s, so my guy had a look, (who I trust) and said the hubs, were OK but there is movement in the drive shafts, more so on one side than the other, but advised me to get both done.
is the noise a kind of whining noise from below the cabin while the engine is cold? it can be propshaft center support bearing then which needs a greasing, see below thread.
https://www.jaguarforums.com/forum/x...ring-faq-9853/
EDIT: just realized it's a 2.2d, this means it's fwd only, right? so this wouldn't be a problem? my bad if so..
AltsXJ8
04-05-2010 08:43 AM
shanemcconn
03-02-2009 11:10 AM
st3v3
01-02-2009 04:58 PM
