new spare key programming
Bought new blank fob and had cut. programmed by the well known diy (4 times switch ignition on etc ) that I've used many times and got the chime. both remote and key operates doors etc key operates ignition but won't start car.
Am told I need to get Jag or specialist to programme.
Any advice??
Any advice??
This old chestnut again. The transponder can be programmed and if you already have 2 working keys (that will start the car) on your car then you can program a new key yourself.
I actually bought a key off Ebay, replaced the blade to fit my car and programmed it myself using my 2 working keys.
If you only have the one then its an auto locksmith job or Jaguar, they have the gear to program your new key.
Also if you have access to a Mongoose system (Jag software) you can program it yourself.
Instructions
Insert the first already programmed key into the ignition and turn to position II
Turn back to 0 and remove the key
Insert the second already programmed key into the ignition and turn to position II
Key programming mode is now activated and you have ten seconds to:
Insert the unprogrammed new key into the ignition and turn to position II
Allow 10 seconds to pass for the system to exit programming mode.
Instructions
Faltwen's technique does work but you don't need to have two working keys. I only had just the one and it still worked.
If you're replacing the blade then open the flip key half way and you might notice a circular indent where the blade starts. You need something small (and a bit of force) to push this rod out, that will allow you to take out the old blade and fit the new one. Then just reinsert the rod and reprogram
No need for any software.
Michael Wittmann
03-29-2016 05:16 PM
Michael Wittmann
03-27-2016 07:45 PM
