Newbie alert! Quick question and thanks...
Hi there,
Just wanted to say thanks to everyone on here for all your posts.
I've owned my 2002 X Type 2.5 Sport for a few months now and after reading up on this forum have just successfully managed to change my spark plugs, air filter and fuel filter.![Cool](https://www.jaguarforums.com/forum/images/smilies/cool.gif)
My question though is...
Once the engine management light comes on do you have to have a dealership reset it for it to switch off again?
The reason I ask is that mine came on shortly after I bought the car and it was this that prompted me to do a semi-service as I suspected that it was due to the spark plugs. However, upon changing them, the light is still on so now I'm worried that I have other issues.
Many thanks for any help anyone can shed on this.
Kris.
Kris.
Received 3,898 Likes
Kris, as long as the problem condition is clear, after 5 starts of the vehicle, the Check Engine light will go out. But, this assumes that the problem has been clear that entire time. You can cheat and pull one of the battery terminals and leave it off for a few seconds and then reconnect. That will be enough to clear the Check engine light and reset the computer. But, a few warnings before doing that:
1) make sure you have your radio code handy as it may be possible that you will need to input the code to allow the radio to work again.
2) this will reset the engine management system. So, the first time you take the car out for a drive, take it easy and do a few accelerations up to about 35 mph and then gently stop. This will give the computer a chance to learn what it needs to do in the way of when to disengage the torque converter, when to drop the engine RPMs, etc. You don't need to drive the car any way special. Drive it like you normally will. That way the car adapts to how you drive.
Thanks for the replies chaps.
Looks like I still have an issue then as the Check Engine Light is still on.
Also, and more worryingly, I now have my ABS light on.
So I've obviously done something while removing the inlet manifold to change the spark plugs.
Any ideas at all?
Sorry to ask so many questions but I know the Jaguar dealership near me will charge me a small fortune just to plug in their daignostics.
Any ideas at all?
![EEK!](https://www.jaguarforums.com/forum/images/smilies/eek.gif)
Hi Aquill,
I'm in the UK, North West to be a bit more specific.![Big Grin](https://www.jaguarforums.com/forum/images/smilies/biggrin.gif)
After reading your advice I'm going to have a look on the ever reliable e-bay for a code reader I think. Looks like a good investment if they are as cheap over here as they are in the states.![Cool](https://www.jaguarforums.com/forum/images/smilies/cool.gif)
After changing the spark plugs etc, I've got the bug now to try and do my own work on the car if I can. (Been stung and ripped off too many times from dealerships in the past.)
I'm currently searching through previous posts on here to see if the ABS uses any vacuum pipes or electronic connections that are connected to or close to the inlet manifold but nothing is coming up as yet.
Thanks again,
Kris
Thanks again,
Kris
Had an interesting chat with the Service Desk guy at my local dealers today.
Explained that I was purely there for advice and that I'd like to do the work myself and he informed me that my ABS light is probably to do with something coming loose on one of the rear wheel hubs. Going to hopefully get the car up on ramps at the weekend and look for anything loose.
Can't remember now what he called it but apparently they send the road speed signal to the ECU or something along those lines and are notorious for the spot welds breaking.
