Newbie with question about these Dam Lug Nuts!
![Question](https://www.jaguarforums.com/forum/images/icons/icon5.gif)
Howdy Gents! good to be here! ![Icon Wink](https://www.jaguarforums.com/forum/images/smilies/icon_wink.gif)
Lemme ask ya....can i swap out the stockers with one of these?
thanx
http://www.oreillyauto.com/site/c/se...22&keyword=lug
Dorman - Wheel Nuts
Part Number: 611-044
Line: DOR
Dorman - Wheel Nuts
Part Number: 611-049
Line: DOR
I appreciate any feedback
thanx
Dorman - Wheel Nuts
Line: DOR
- AutoGrade
- 5/8-18 x 21/32"
- Hex Size: 1-1/16"
- Open Nut
- 90 Degree Seat Angle
- Limited Lifetime Warranty
- Universal Product
Dorman - Wheel Nuts
Line: DOR
- AutoGrade
- 3/4-10 x 3/4"
- Hex Size: 1-1/4"
- Open Nut
- Universal Product
You have the same size (at least thread specs) as the s-types, and those guys have found a few excellent replacements. You need to check your shaft length and diameter, make sure you get the right dimensions, but if you can show they're identical to the s-type's, those members have done all the legwork for you already.
Drop over there and search for 'lug nuts'. Gluck!
Location: That Rectangular Hole in the Consciousness of America
I've had to replace two lug nuts and the corresponding wheel studs on my X-type thus far as they seized for no apparent reason (I always use a torque wrench). I replaced then with these from NAPA...
Wheel stud P/N BK6414225 $1.83 each
Wheel nut P/N BK6414244 $2.51 each
These parts are listed for a 2002 Lincoln LS. The studs are a tiny bit longer than stock, but otherwise identical. The lug nuts also fit perfectly, but are slightly smaller in diameter at the top of the hood (i.e., the top of the decorative stainless steel cover, which is purely cosmetic). If you want all five lug nuts on a wheel to match perfectly, just replace them all!
87vertgt it's worth the dough to get a one piece chrome nut (no more tin cap) like these http://cgi.ebay.ca/20-JAGUAR-LUG-NUT...item5ad7486c81 as long as that's what your current one with the washer looks like.
morhd +1
The stock lug nuts are a pain in the *ss if the SS skin happens to spin on the nut.....been there. They are a mag type nut, but Jag had to make things difficult by using a unique shaft length and diameter.....hard to find, but yeah, Ebay is your best bet. I got a set of solid chromes for $75.
![Icon Teeth](https://www.jaguarforums.com/forum/images/smilies/icon_teeth.gif)
thanx for the response!
we dont have a napa...just a Oreillys...
I looked up 2002 Lincoln ls and found the lug nuts
Dorman - Wheel Nut
Part Number: 611-100
Line: DOR
- AutoGrade
- Specialty Nut
- M12-1.5
- Acorn (1 Piece Construction)
Question? Can I used these lugs without swapping the studs?
Thanx mang !
morhd +1
The stock lug nuts are a pain in the *ss if the SS skin happens to spin on the nut.....been there. They are a mag type nut, but Jag had to make things difficult by using a unique shaft length and diameter.....hard to find, but yeah, Ebay is your best bet. I got a set of solid chromes for $75.![Icon Teeth](https://www.jaguarforums.com/forum/images/smilies/icon_teeth.gif)
![Icon Hyper](https://www.jaguarforums.com/forum/images/smilies/icon_hyper.gif)
FS[Western US]: Jaguar xk accessories for sale
jfitzoz
09-07-2015 04:28 AM
