No chimes, warnings or turn signals make noise
Received 3,901 Likes
Spikepaga (05-30-2014)
Spike, you are going to laugh at this, but the speaker is built into the turn signal stalk. So, you will need to drop the bottom half of the steering column to access the switch and then you should see the speaker at that point. It is very possible that you will need a new turn signal to make the buzzer sound.
Now, just to make sure that it isn't a problem some where else, if you have a multimeter, you can connect the red lead to the orange/yellow wire on the plug for the turn signal stalk and then the black lead to the black wire on the turn signal stalk. Then, when you apply the turn signal, this should cause your multimeter to start "bouncing" between 12 VDC and 0 VDC.
Please keep in mind that there is a second buzzer that is built into the GEM module that does the alarms for like "key in ignition", headlights left on, etc. So, if you have lost that, then that is almost a garantee new GEM module as this speaker is internal to the GEM and if that fails, there is no replacing it unless you feel really adventurous.
MC36
US Lower Atlantic
09-01-2015 07:34 PM
