No crank, dsc fault, gearbox fault and stuck on parking HELP!!!
Hi Guys,
2002 x-type 112,000 miles 3.0L
The other day while driving all my cluster gauges stop working and on my radio screen appeared the message ignition off(while i was driving) i pulled over, turn my car off and after that i couln't get it to start again (no crank). I started checking the fuses and found F84 (Mini 5 Tan Instrument cluster, passenger airbag fascia light, seat weight sensor) burned I thought that was the problem so i replaced it, my cluster works now but still NO CRANK and the display says DSC SYSTEM FAULT, GEARBOX FAULT my temp gauge light is on, my gas light is on , abs on, and on top of that its stuck on parking.
before all this happened i noticed that when ever i turn the key to start the car it wouldn't do anything for a couple of seconds then it would start please guys help!!!![Icon Gunhead](https://www.jaguarforums.com/forum/images/smilies/icon_gunhead.gif)
Rlover
03-30-2016 10:04 PM
neruda
10-18-2015 01:19 PM
