No crank. No fuel. No spark. No OBD2 code. DSC System / Gearbox / Transmission Fault
This is from a thread earlier, to recap everything that has been done:
This is for a 2002 Jaguar X-Type. 2.5L V6. AWD. Automatic transmission. Gearbox Fault and DSC System Failure is stated on the console. The CEL and ABS are both on.
When the key is inserted, and put in the "ON" position, the starter does not engage for the engine to crank/turn over. Nothing happens.
The key that is used, the remote can lock/unlock/pop the trunk and etc.
Several OBD2 code readers have been used, none of them were able to pull a code. The port does have power, as the units light up when connected.
If power is crossed on the starter solenoid, the starter engages and the engine turns over. Starter fluid is used, but nothing happens.
A new battery has been used with and without a jump starter and battery charger set at 6 AMP. No change.
The TCM/TCU was pulled, and it appeared to have no moisture/water damage, although the vehicle has a cracked windshield. The TCM has been reinstalled. No change.
The trim around the shifter has been pulled. The J-Gate solenoid does not move under its own power. If the tab is pushed down, then the shifter can be placed out of park. If the shifter is pushed forward to park, it hits the "park" switch which makes a click in the ignition. When in the "R" position, if an object is behind the back-up sensors, sounds come saying it is too close.
The intake box has been removed, and the PCV tube below it is NOT cracked.
A spark plug has been pulled out, while power is applied to the starter, there is no spark.
A threaded nipple on the fuel line just left of the engine had a been pushed in and a little bit of fuel came out (I'm assuming what was pressurized). I'm assuming its for a fuel pressure guage. When the key is turned, no more fuel comes out. I'm assuming the fuel pump is not functioning.
The vehicle is parked on a slight incline, the rear is on the incline. At first, the fuel tank read below empty. I poured in a gallon of gas, and it the reading changed to 1/8 tank.
The intake tube has been taken off, and the butteryfly valve for the throttle body does not move at all when someone presses the throttle.
The ground for the ECU near the power steering reservoir has been removed, sanded and re-installed. There wasn't any corrosion, but I did it just in case. No change.
The inertia switch has been reset multiple times, and no change.
To recap: No crank. No fuel. No spark. No OBD2 code. DSC System Failure. Gearbox Fault.
The only thing I can think of is the ECU, but I cannot remove it. I've removed the two nuts in the engine bay. Then I removed one nut holding the bracket under the dash. I wasn't able to get it out. There appears to b a 5-pointed star with a raised center that is keeping me from pulling the harness off. Besides that, I do not know what other nuts and bolts are holding it in.
Please let me know if you guys have any ideas, because I'm pretty fresh out of them.
Thanks in advance!
Thanks in advance!
I'm pretty certain I won't be of much help, so here goes.
Do you possibly suspect the key switch itself, since you can effectively override it at the starter motor? Do you not get any spark (which implies that it's more than just the key switch) and firing of the cylinder?
Did you think it might have been the shifter not fully engaging the Park switch on the trans shift linkage, but that turned out to not be the problem?
Wow ... what a pain in the tush. Where in Mich are you located?
It's got a dead 'will-to-live' circuit.
Bad, or incorrect transponder key? The remote may operate the door locks, trunk, etc., but the key itself needs to be programmed to the car.
The number of electrical circuits you've mentioned as being kaput would lead one to believe there's a single, common culprit. Good luck with that......hate when this happens! Been there.
Is the key you have the one that came with the car? (the key transponder is not interchangeable from car to car) If you don't have the original key, you're kinda screwed. You'll need to contact a full-service locksmith or a Jag dealer to sort out the transponder programming........if that's the problem.
I really hope its only just the key. The key that I have turns the ignition. What is the likely hood that the keys I have turns the ignition cylinder, but is the wrong key? Is here THAT many different combinations? What are the tests to see if the key is bad? I don't think the Security light turns on, but I will check tomorrow.
Any other ideas? Anyone know how to pull out the ECU?
Thanks.
I bought the torx bit, and took off the connector. I read if it were bad, the connector/pins would be green and the ECU would need to be replaced. The connector and pins were in great shape when I took them off. Any other ideas?
Check the inertia switch located in the passenger kick panel. Make sure that the button is depressed. Sometimes those will pop up and kill the spark, fuel pump, and other components. My car wouldn’t start and the windows wouldn’t go up. I checked that switch and depressed the little button on it and all was well.
trosty
26
12-18-2022 06:40 PM
OkieTim
09-08-2015 04:48 PM
