No Heat Now?
I had a problem with a bad battery(cracked at neg post).
The car was totally drained and had error phantom error codes.
Now i put the Battery in all codes cleared,but now 1st start and i get NO HEAT at all.
What electrically(Fuse,curcuit,relay or electric pump) could cause this to happen
Thanks for any and all suggestions.
Do you still get air blowing out of all of the vents? can you change where the vents blow air (feet/face.) If any of those are problems then you may have problems with the internal baffles of this car getting stuck in place. Before you do this however, check all of your fuses especially after you have replaced a bad battery. There is a guide to the location of all of your fuses in your manual which will help you figure out which fuses run what. I would just recommend running through all of your fuses (under hood and in cabin) as precaution after replacing a bad battery seeing as how anytime you mess with your electrical system, you can blow fuses without even knowing about it. Hope that helps and if you think it is the baffles, just do an advanced search under the x-type forum and you will find some results.
