No kickdown car splutters on acceleration
Old 09-22-2017, 03:12 PM
johnkent's Avatar
Default Kickdown / Acceleration problems
Am having problems with my x types Kick down the car splutters there's no acceleration and going up hill , well it won't
Engine idles fine revs fine doesn't seem to misfire no Engine warning lights up
X type 2.0 v6 sport 2003 65,000 miles
Anyone got any ideas
Old 09-22-2017, 06:06 PM
Doug's Avatar
Received 10,891 Likes on 7,160 Posts
Clogged fuel filter?
Old 09-23-2017, 01:53 AM
JagV8's Avatar
Received 4,533 Likes on 3,942 Posts
Though it could be misfires - the car will normally back off long before you feel or hear them.
Worth a check for pending codes.
BTW, wrong sub-forum.
Old 09-23-2017, 03:33 AM
johnkent's Avatar
Thanks lads
i'll try fuel filter
was also thinking misfire
i will try my code reader to see if any are stored
is it difficult to replace fuel filter and spark plugs ?
cheers
Old 09-23-2017, 05:32 AM
iownme's Avatar
possibly the throttle body needs to be removed and cleaned
clean mass air flow sensor
keep driving hard until it gives u a check engine code
Old 09-23-2017, 06:13 AM
johnkent's Avatar
Just one thing when i bought the car it was low on petrol, light was on, i put £10 in and light is still on , theres no leaks, i'm wondering if its sucked up some dirt from tank, if it was gearbox ( auto) would i get an engine light come on if there was a fault with it?
Also how involved is it to change fuel filter and plugs
Old 09-23-2017, 08:41 AM
johnkent's Avatar
13 codes logged cleared them off and 2 remain wont clear
code 1108 and 1000 pending
but 1108 stored when running
anyone shed any light on this
Old 09-23-2017, 08:52 AM
johnkent's Avatar
Heres the 13 that were logged
0306
1314
0102
0112
0341
0346
1108
1549
1646
1647
1603
1000
1108
Only 1108 and 1000 remain they wont erase
Old 09-23-2017, 09:00 AM
Dell Gailey's Avatar
P1000 = ignore = incomplete drive cycle (after clearing codes)
P-1108 =
P1108 EMS
OBD II
MAP Sensor sense circuit
high voltage
Ignition ON 10 seconds 2 N ECM Default:
– Default value of 1.013 BAR
(29.92 in hg) used
PI1
-127
MAP Sensor sensor ground circuit (to splice):
open circuit
MAP Sensor to ECM sense circuit:
short circuit to high voltage
MAP Sensor failure
Posting in these forums =
johnkent (09-23-2017)
Old 09-23-2017, 09:50 AM
johnkent's Avatar
Would this cause no kick down acceleration and a complete failure to go uphills ?
Found the Map sensor cleaned it plugged it back and bingo no code, lets see how it drives next
Old 09-24-2017, 04:32 AM
iownme's Avatar
a sticking flap in the throttle body caused by carbon buildup is a likely cause.
remove throttle body.
clean with the appropriate cleaner and replace.
Old 09-24-2017, 05:00 AM
johnkent's Avatar
I'll have a look at throttle body next week
now the Map sensor has been cleaned I don't get the code anymore but EML Led doesn't work
Would a dodgy Map cause above symptoms
just a few more things
the remote key fobs won't unlock
they lock / boot release and lights button work tried the ignition flap that's ok
it won't pair the fobs with car either
also drivers seat electrics don't work
are these common faults ? And easily fixed
Old 09-24-2017, 09:00 AM
Alfadude's Avatar
Probably best to start new threads if you are having other unrelated issues to allow you to get quicker and better responses to those issues.
Old 09-24-2017, 01:11 PM
iownme's Avatar
fuel filter is easy, 5 minutes
spark plugs are a pain as intake and other stuff has ro be removed to access them. takes about 2 hours the first time
