No power
No power
Hey guys I was driving yesterday and ended up hitting a center median making all four wheels hit up on 6 inch curb , Was moving at about 25 mph and the car immediately shut down loosing power to engine, transmission, windows . All lights work including the dash and radio .. I have over 20 dtc's and I believe the theft deterrent system and fuel shutoff happened . Majority is the can bus evaporative system . How can I get power to my windows so they will roll up and also do a hard computer reset so it'll drive and start ?
You might want to be wary of a possible bent rim or at the very least you may have knocked the wheel alignment out.
Visually check the rim to see if it has any impact deformity.
When you are next driving it, see if the car is now tending to pull left or right since the kerb incident - wheel alignment out if it is.
Also check to see if you have picked up a vibration in the car or steering wheel as you get the opportunity to bring the car up to freeway speeds - could indicate a bent or crushed rim.
vidx3m
05-29-2020 09:58 AM
