No power brake on 2.5 2001
Hey everyone, I've read about this issue before here, but I'd like to gather the latest and greatest solutions and possible causes in this post.
Some months ago my gf's X-type started to lose brake assist (hard pedal) which eventually caused her to rear end another car. While I'm fixing everything that broke in the crash, I need to figure out how to fix the brake issue to make the car safe again.
A couple of months before power braking failed, I've replaced the front pads and disks as they were very unevenly worn out (lack of maintenance). After that I asked a shop to do a brake fuild flush.
What I know so far:
What I know so far:
- manifold vacuum is ok, measured with a vacuum meter
- manifold to booster (servo) pipe seems ok, the one way valve works for sure, despite looking a bit worn out on the outside (engine heat)
- when the car is started with the pedal depressed, it doesn't go down enough I think (as per the workshop manual test)
- if there was a leak at the joint of the bootster pipe and the manifold, would the engine be running rough?
- how do I tell if the booster itself is ok?
flukinfool
07-01-2016 10:40 AM
sunchip
01-28-2015 08:21 AM
icsamerica
12-22-2012 09:41 AM
MarcB
01-16-2012 10:29 AM
