No reverse after cooler line busted.
I bought a 2003 x-type with 85k on it with a busted trans cooler line. The seller said everything worked perfect before the line blew. I replaced the line and drained all the old fluid out from the cooler line. Filled the trans up with castrol multi import which is fine. All of the foward gears work perfectly, but reverse just slips. I know this has happened to other people but I've never seen a fix. The trans isn't low on fluid just to make sure its kinda overfilled.
Location: That Rectangular Hole in the Consciousness of America
There was a "No Reverse" thread here the other day. Here's the long and short of it:
Hope this ain't your problem. Good Luck!
Have you just had the ATF changed? That could be the reason:
http://www.raybestospowertrain.com/p...g_Problems.pdf
Will P
09-19-2018 08:36 AM
