No reverse after tranny fluid....HELP!!
Please tell me this can be fixed. Ill try to make this long story short. Took 02 X in to have the leaking oil pan gasket and cracking drive belt replaced. While there they drained tranny fluid and refilled. I remembered something on here about not removing hex bolt from the top, I tried to tell them but when I looked he had already done it. Now reverse doesn't work. I don't know what to do now. And neither does the mechanic apparently. I hope one of the techs is out there and can help.
well, yes, it is messed up. The reverse band brake bolt was removed.
The trans shop I talked with has a tool that can reset this most of the time. It is a well known mistake and the really good trans shops can get you straightened out for a minimal charge. The rest will tell you you need a complete overhaul.
queenmb (08-04-2011)
FS[NorthWest]: 2004 X-type 3.0 24,500miles! $8500
millertic
09-30-2015 08:11 PM
