No start after radio removal
Do a search on here, but I believe the problem is you have removed the radio. There is something in the communication where the radio has to be in the loop. I can't give you a more technical reason, but you should be able to find it with a quick search on here. Try putting the radio back in and see if it starts.
The radio is a box taped up and ready to be shipped back to the manufacture. I think I might have jumped the gun a little,I put a meter on the battery and it was reading 10.1 volts not enough to crank, the radio was the last thing I the I touched and she started fine before that, so I assumed it had something to do with that. Currently I am waiting on a battery charger I have in storage, I will charge it,hopefully start it and to Autozone and have it tested and will report back, Thanks for the quick respones.
