(Not the Fan) Whining sound in cabin?
I get a high piched whining sound in the cabin when driving at almost any speed.
It does not sound mechanical. I can make the sound go up and down with the gas pedal.
I thought it was coming through the speakers but if I turn the radio off the whine is still there.
It's getting real annoying.
Any ideas???
2003 X-Type
Any ideas???
2003 X-Type
Guest
Posts: n/a
Guest
Posts: n/a
RE: (Not the Fan) Whining sound in cabin?
I have the same issue in my 97 XK8, however I purchased it without realizing it had a ton of after-market amplification installed. I'm pretty sure thatit is the cause of the sound, and I have found a loose wire behind one of the rear speakers, but I'm not clever enough (or have enough time) to correctthe issue just yet.
Guest
Posts: n/a
by the description I will almost guarentee its a grounding issue, but to be honest i don't know the x-type's setup. I know a poorly grounded amp can cause what you have described but iirc the 2003 x-type did not have an amp, just the 04+, but it sounds like an audio issue. fluctuating with the RPM would be interference from the alternator I believe and that is still present with the radio off, but to make sure its from the speakers why not have someone put there face right next to it and see?
Guest
Posts: n/a
Guest
Posts: n/a
see that is what I always thought until I actually had this happen on a car I was working on. after doing an audio install, a "whine" such as what I think the op is saying was apparent. Talking to a friend of mine, he said that it was the ground for the amp, but it didn't make any sense as to how that could be, so I dismissed it. Maybe 2 weeks later, the next chance I had to work on it, I figured what the heck and changed the ground for it. After checking to make sure it was grounded with a multimeter and being satisfied, I started her up and all was good.
So there is still a good chance that this is not even close to what is going on with the op's car, but surprisingly enough, radio off, w/e it can still happen. Disconnect the harness and it shouldn't though.
Mdoog, car has stock audio system - no amp. It does sound like what you are describing. I,ve heard that whining sound and thats what it sounds like. This sound started a few months ago. Nothing has been done to car.
Sound is the same with radio on or off. I'm sorry I can't get my ear to speaker, buy it does seem to be coming from them.
Thanks for your help.
abonano
25
09-25-2015 10:43 AM
