o/s/r window problem
a few weeks back when we had the snow and ice my grandson tried to open the rear window when it was frozen shut , something broke and once defrosted the window dropped down . i have removed door panel but cant work out what drive it up and down . is it a cable because there seem to be a metal wire loose in the door motor works fine but cant find drive pulley .... can anyone help please?
Received 3,898 Likes
Carlos, what you are describing, it sounds like the window mechanism has failed. You will need to buy a new mechanism. This will entail buying the drive motor, the drive cable, and the associated pulleys. This is one big unit. This is the same unit that you would end up buying if your motor for the window failed. Replacing it is not that difficult. It will involve manually lifting the window up and then taping it in place (duct tape works for this). Then you can remove the retaining bolts for the drive mechanism. Finally you will need to loosen the fasteners holding the mechanism to the glass. From there you can remove the old mechanism and install the new one. Then installation is the reverse process.
99xk8guy
06-05-2023 06:28 AM
