Odd tire size?
Odd tire size?
Just recently purchased a 06 Base XType with 40000 miles. The tires look a bit worn and I plan on replacing them. I assume they are the original tires as the car doesnt have that many miles on it. They are Michelin Pilot MXM4 235/50 17"
This doesn't look to be a standard size? When I look for tires on the internet, this the size is not listed under standard size. When I replace them, should I look to go back to the original size or is it ok to keep this size?
Received 3,887 Likes
Ron, as long as the tires are not rubbing during normal use, you can use that size tire. Yes, it will throw off your speedo a little bit, but not that significant. The bigger thing will be the additional cost of keeping that non-stock tire size. What you will find is that there will be fewer tires to choose from. For example, the 235/50R17 has 41 options, the 235/45R17 have 103 options, and the stock 225/45R17 have 166 options. You will probably find that the 235/50R17's will also be a fair bit more expensive. So, up to you.
ronfieldsjr (08-19-2012)
Gerard Radimaker
09-13-2015 10:33 AM
lickahotskillet
09-11-2015 07:54 PM
