Oil Change
Guest
Posts: n/a
Received 9,011 Likes
Or, you could just go to Wal-Mart and get a Motorcraft FL-400S filter and 7 qts. of 5w-30. You didn't say what engine is in your car but my 3.0 takes 6.8 qts. The Motorcraft filter is the same one the Jag dealer uses except it says Ford on it instead of Jaguar. It's also $4 instead of $11.
You need a 13mm wrench or socket for the drain plug. It's super easy to change the oil in the X. The only thing that is a pain is that once the filter is off, oil comes out on the exhaust. That is solved by sticking a diaper, yes a diaper, in between the filter and the exhaust pipe before removing it.
Paul
Paul
Received 3,915 Likes
Your motor does not require any special oil that can only be gotten at the Jaguar dealership. As long as you stick with a major brand name (Valvoline, Mobil 1, Halvoline, Quaker State, etc), you will be just fine. The big thing is to use 5W-30 oil in your car and fill it to the proper levels. As for the argument over using synthetic, synthetic blends, or standard motor oils, I will leave that up to you. You will get 20 different stories as to why synthetic is better than dino oil, dino oil is better than synthetic, etc, etc, etc. The big thing I would recommend is using a shop that will stand behind their oil changes so should something go wrong, you are covered. I personally change my own oil so I have no one to blame but myself. Been doing that for over a year on my Jag and 20+ years on my vehicles. No problems.
Paul
Paul
aholbro1
08-05-2021 05:02 AM
