Oil in coolant compression OK
I am diagnosing a friends Jaguar X-Type 2002 2.5 v6. There is oil in the coolant and a misfire. He claims that the car over heated twice and the coolant level got low. After the 2nd time he says the misfire started. I checked the coolant which is low in the resivour but is very brown. The oil however is not milky. I initially thought it was a head gasket problem so I compression tested all 6 cylinders. They all read within 5 to 10 PSI of each other at approx 180.
Without tearing down any more of the engine I am looking for other possible causes. Any suggestions are appreciated.
Thank you.
Thank you.
Try this thread! Starting @ comment 5 may not be the problem but its place to start BEFORE you tear somehting apart.
https://www.jaguarforums.com/forum/x...uper-v8-75945/
OkieTim
09-08-2015 04:48 PM
