Oil Filter System
Have these to install, any and all clues as to what goes where will be appreciated.
AutoEngineLube Engine Oil Pre Lube System Order Now
Ultimate Oil Catch Can - 42 Draft Designs
Battery moved to make room
Kleenoil Bypass Filter System Demonstration - YouTube
I have prototype electric oil pump and water pumps which are much simpler to retrofit then this.
Generally speaking there is an adapter (Summit Racing) that replaces the stock oil filter that has two fittings for lines. An in and an out. You would plumb the external filter in there.
Things they did not talk about that would concern me. Restriction, adding lines are going to cause some restriction. As the filter clogs up how much will it restrict oil flow? Many filters (not sure if ours does) have a bypass built into them for when the oil is very very cold, or should the filter clog up.
I am not an expert on this motor and do not know how well the oiling system works.
If I was designing this system for my car I would use an external electric pump (Summit Racing) and tap the oil pan for lines in and out. This way you are cleaning the oil without putting any strain on the stock oiling system. I would first see how the oil temps run and then think about using an oil cooler, if needed.
I am very interestedin your project, please keep me informed. I like this stuff!
Received 2,263 Likes
I have used the per-lub systems on some motors and like them. Not very costly and gives you full oil pressure on start up. Now if you are road racing they also act as a pressure supply should your sump, in the pan, suck up some air on a hard turn. I use them on trucks and tractors that may sit for a very long time between starts.
The catch can is for you PCV line.
Received 3,887 Likes
The catch can is a waste of money as I see it. If the PCV valve is working like it should, you should be getting minimal oil down that line. If you are getting lots of oil down the line, replace the PCV valve. How many PCV valves can you buy for the price of the filter? More than you can probably use in the life of the car.
As for the pre-lube system, if you are starting your car every few days, the amount of additional wear from starting is going to be insignificant over the life of the car. If you are after something that will reduce engine wear, then you want to find one of the micro-filtration system for a vehicle. See https://www.amsoil.com/shop/by-produ...?code=BMK23-EA. This is just one example of many out there. This system installs a second oil filter that takes a small amount (normally around 10%) and sends it through a special filter that will filter down to a micro or two in size. This gets rid of all the carbon chunks and super fine metal pieces that cause most of the engine wear. With this system, you install a quality full synthetic oil and then you simply have to change the filters (still uses a standard oil filter to get the "big" chunks) and this special fine filter. They also recommend get the oil analyzed every say 10,000 miles (15,000 KM) to make sure that the oil contains sufficient detergents and is not breaking down excessively due to age/being over heated. With this setup, you can go 50,000 plus miles between true oil changes (still change the filters ever 5,000-7,500 miles). All you are doing is watching the oil parameters and changing out the oil once you start hitting a level that is deemed "outside of normal".
santer (01-26-2016)
