Oil leak on top of engine
I am starting to pull off parts to do a tune up and replace my top radiator hose, knock sensor and found what looks to be a sizable oil leak coming from somewhere under the intake manifold and running down the side of the engine and pooling on the transmission. Is there anything other then the valve cover gaskets that could cause that big of an oil leak?
I have attached a pic.
Okay so I got the upper and lower intake off and it doesn't look like the oil is coming from the valve cover. It looks like its coming from the base of the cylinder head. Also if it makes any difference the upper and lower intake had a lot of oil in them that came out when I removed them.
![](http://i57.tinypic.com/nps3no.jpg)
![](http://i57.tinypic.com/k06iyh.jpg)
Received 3,909 Likes
foxteca, I would start with simply applying a little bit of grease remover (Simple Green is a good product that is cheap to use) and then use a hose to wash everything off. From there, drive the car and see where the oil is starting to pool. From there you can get a better idea of where the problem lies. If it is still looking like it is coming from the base of the cylinder head, then you are looking at a bad head gasket where the problem lies with the oil channels, not with the cylinder compression or coolant channels. This can happen.
Oil in the upper and lower plenums is not uncommon, especially if your PCV valve is bad and it is allow too much oil by. Replace the PCV Valve and clean up the plenum too to keep things as clean as you can.
BrentGardner
28
04-26-2024 03:08 AM
rusty37
06-07-2016 04:43 PM
