Oil for Manual Transmission - source in UK
Old 02-12-2010, 04:31 PM
TGK711's Avatar
Default Oil for Manual Transmission - source in UK
I have a very notchy gear change on my manual AWD gearbox. I've read that using a newer lubricant can dramatically improve this situation.
I know the gear change issue is common on the MTX75 boxes and has been discussed on many forums and threads.
Basically I want to source the Motorcraft XT-M5-QS fluid but is this something I can source at my local Ford dealer? If not is there an equivalent spec for the Ford product in the UK?
Cheers,
Grant
Old 02-12-2010, 04:36 PM
Krisfx's Avatar
Hi Grant,
Not sure about your local Ford Dealer but I found a selection of decent gear oils the other day here if you don't mind mail order?
http://www.demon-tweeks.co.uk/produc...09&tlgrp=RD002
Cheers,
Kris
Old 02-12-2010, 06:56 PM
TGK711's Avatar
Thanks Kris, haven't used Demon Tweeks for a long time (during build of my Westfield), but good idea.
During my search I did find the following:
Manual Gearbox.
Classification: WSD-M2C200-C
Viscosity: 75w/90
Capacity: 1.75L
Jaguar: Castrol BOT 130M (C2S19889) £12.78/Liter +VAT
Ford: Motorcraft XT-M5-QS (FINIS:1045737) £10.71/Liter +VAT
Alternatives;
Motul GEAR 300 75W-90 Ester Synthetic.
Hopefully this should allow me to pick up the Motorcraft at my local Ford dealer - closer and cheaper than the Jag one - they may even be open on a Sat morning
Grant
bamforp
08-14-2024 05:36 PM
GordoCatCar
01-02-2017 01:10 PM
ZJag
26
09-05-2016 03:33 PM
Scarecrow
03-28-2016 03:17 AM
OkieTim
09-08-2015 04:48 PM
Quick Reply: Oil for Manual Transmission - source in UK
