oil on spark plug
You might just have a bad coil in cylinder 3. Not sure where you got the misfire in cylinder 6 of P1316. I believe that one is for excess emission and would make sense with the P0420. Check/replace the coil in cylinder 3. When the light is flashing you shouldn't drive teh car. Start there and see what you have.
Received 2,626 Likes
Do not operate the vehicle under conditions that cause the MIL to flash as catalyst damage is occurring.
When P0420 or P0430 are present, they usually indicate the catalytic converter on that cylinder bank needs to be replaced. Changing or swapping the oxygen sensors is not going to eliminate P0420.
hjt1948
03-05-2016 05:20 PM
studentper
02-24-2016 05:08 PM
