oil types for x type
Hi all I'm looking for is the correct oil grades for a manual x type 3.0 gearbox.
The correct oil grade for transfer case.
And oil grade for rear differential.
I have had a good look through various posts but all seem to have conflicting views.
Does anybody know what oils I need as I have just got my first x type and I want to give it a good service.
Manual Gearbox takes SAE Grade75W-90
Ford Specification WSD-M2C200-C 1.75 Liters
Transfer case and rear end take SAE Grade 75W-140
Ford Specification M2C192A synthetic (1.2 Liters for rear end, 550ml for transfer case if draining/refilling using drain plug)
There is some good info on swapping gear box fluids here
https://www.jaguarforums.com/forum/x...n-plugs-34404/
When you get a minute, please follow this link New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum to the New Member Area - Intro a MUST forum and post some info about yourself and your vehicle for all members to see.
In return you'll get a proper welcome and some useful advice about posting to the forum.
stanjag
08-30-2015 10:35 AM
