One for RacerX
Old 09-19-2008, 09:24 PM
Dennis's Avatar
ud
Default One for RacerX
Hi, Welcome back..I never knew you before now, but I've seen some of your great posts and help..Nice to meet you at last..
Anyways..We here over the past 9 or 10 months on several threads have discussed and re-discussed and then discussed some more, the topic of the TRANNY FLUID..Please bear with me..
We all know how fussy this damn JATCO is and we also believe this "filled for life" BS is BS!!.
Okay..I have found only on the web that Royal Purple Multi-spec will meet Jatco's specs, Valvoline MaxLife will too..BUT, and it is the onlyBUT that matters..Will these aftermarket fluids have adverse interactions with the current factory fluid???..Some of theexpert JAGUAR X TYPE techknowledge folkstell us yes,they will not mix well and lead to a failed Transmission...Keeping in mind, if the tranny is just drained, it still has a torque converter and coolerfull of the old fluid still, so there is no way to completely drain the tranny...and keeping it simply at the same time.
I want to change mine, at least do a couple of drain and refills to flush most the old fluid out..But I hesitate for fear that I may cause myself problems in the long run..
Oh, the motivation here is that the Dealer only sold JATCO fluid, is around $45 to $55/qt..And we need at least 9 quart...So there has to be a cheaper alternative ..
Okay I'm done..Hope to hear from you on this..I'd like to hear your take.
TIA
Old 09-19-2008, 10:01 PM
Received 9,010 Likes on 4,113 Posts
Default RE: One for RacerX
Size:  6.3 KBName:  X6JYMSAAB5.jpg
Size:  6.1 KBName:  AudiX6JYM-2.jpg
Size:  6.4 KBName:  T15ESSST101-1.jpg
Dennis....he's at the pub mate, you've got no chance!
Jim
Old 09-20-2008, 11:00 AM
Dennis's Avatar
ud
Guess he's sick of talking about this issue too..
Old 09-20-2008, 11:33 AM
racerx82's Avatar
lol, sorry, was at the pub....ok, tranny fluid, my fav topic.
sealed for life=crap. First thing first. type of tranny fluid. DexIV. period. All that other nonsense is just that. If i remember correctly 10qts, (9.3) that includes the troque converter.
To drain, my fav way, disconnect the lines going to tranny cooler. In and out. Get a pan, put both line in the pan securely, or have someone hold them. start car. fluid will drain (with some force), when it starts to "gargle" turn car off. Everything is now drained. Open the plug on top of tranny, use long funnel and add about 3-4 qts, start car, and add remaining fluid while car is running. Now, if want an Altimate clean job, repeat this step with the clean fluid,drain and add clean fluid again. reconnect everything and you're golden. Approx time, 1.5hrs drinking beer, 2.5hrs.
Hope that helps.
Old 09-20-2008, 11:46 AM
christo's Avatar
question - the gargle, where willI hear that? Will the sound be coming from the tranny lines or will I hear it from the tranny? Also how do I get to the top of the tranny and insert the funnel? Will the tranny have to be dropped?
Old 09-20-2008, 11:51 AM
racerx82's Avatar
You'll hear the gargle from the disconnected lines, no, tranny will not need to be dropped, but you may have to remove the Air clearner assy to get to the plug. If you have real small hands, maybe you won't have to, but it makes the job that much easier if you remove the airclearner assy IMO.
You can't miss the plug, hex nut, about 15 mm (i think) don't remember.
look between the aircleaner and engine, you should see it.
Old 09-20-2008, 11:55 AM
racerx82's Avatar
Disregard the part about the airclear....i was thinking of another car...sorry.
Old 09-20-2008, 11:56 AM
Dennis's Avatar
ud
Thanks buddy, I assume you have performed this with this type of fluid you mentioned with no problems..
Can you tell me about how you estimated the full mark?..or did you just measure what came out and put back in the same amount?
Thanks again
racerx82's Avatar
Might be the battery assy i was thinking on the jag....
Old 09-20-2008, 12:04 PM
Dennis's Avatar
ud
ORIGINAL: racerx82
The fill port is under the battery box and it has a rubber cork in it on the X
Old 09-20-2008, 12:18 PM
racerx82's Avatar
Don't remember the cork...mine had the hex nut. Directly under the batter i think.
You can measure what you took out, or just add the 10 qts. If you crawel under the car, the check level plug should be easy to spot. Add 8 qts, open and check, if no fluid comes out, add another qt. etc....
Old 09-20-2008, 12:23 PM
Dennis's Avatar
ud
Thanks again....yeah, the X trannys have the corkin thefill port..
Old 09-20-2008, 12:30 PM
racerx82's Avatar
lol, that is/was the vent (on myx-type) But if you can remove it without damaging it you should be good. Mine was on top of the tranny. hex nut. lol
good luck
Old 09-20-2008, 05:42 PM
Dennis's Avatar
ud
Hmm,interesting..my JTIS manual clearly shows it as a cork (cap) and not a hex (allen plug)
Oh Well none the less, it will work for me to fill..But thanks for your help anyway..
Old 09-20-2008, 05:47 PM
Size:  6.3 KBName:  AudiX6JYM-2.jpg
Size:  9.9 KBName:  tshirt03-2.jpg
You gonna let us know how you get on Dennis?
Jim
Old 09-20-2008, 06:10 PM
racerx82's Avatar
ah, Dennis is a tease....Jimbo! what up buddy! Got some beer and am drinking the night away!
Old 09-20-2008, 08:54 PM
Dennis's Avatar
ud
As in NO EXPERTEASE
Old 09-21-2008, 09:08 AM
racerx82's Avatar
hahahaha...lol nice...
Old 09-21-2008, 05:34 PM
Lol.......nice one Dennis
Could be a MALT teaser too?...lol
Jim
Old 09-21-2008, 06:14 PM
racerx82's Avatar
i'm not even gonna go there....
Quick Reply: One for RacerX
