Orange oval light, no code.
I was driving to work and the orange dash light came on along with the "Cruise not available" message. No change in performance or otherwise. The light wasn't the cel, but just the oval warning light.
All went back to normal for the drive home, with no light or message. Eagerly went to pull codes.....nothing.
Anyone else ever get this?
Jaguar's are extremely sensitive to voltage. When they start throwing warnings for no apparent reason it is usually voltage related. In your case I think it might be corroded battery cables/connections.
I would remove and clean the connections and insure the are good and tight when reinstalling. Use a good electrical cleaner on the cable end connectors. The cables are bad about corrosion at the joint.
My scanner doesn't seem to report unconfirmed or frozen frames.
Just the oval, orange, symbol-less dash light.
Thanks, I'll take a look!
