Other 18" wheels that fit x-type
Heres a list of other vehicles with the same PCD - 5x108 - Bolt pattern - Wheel-Size.com
But you will have to bear in mind the offset of the wheel, as not all of them will clear the suspension on the X Type.
If your going to run a 7.5x18 wheel, you will need an offset of at least ET52.5
If your going to run a 9x18 wheel, you will need an offset of at least ET43
wyxtype (12-19-2016)
