over pressured cooling system
Received 2,263 Likes
Received 3,907 Likes
Test you pressure cap to make sure it is working by releasing pressure. But it will only need to work if the car is overheating. Is it?
Now if the pressure builds up real fast, like 30 sec, it is the head gasket. You can use a tail pip sniffer by the cap, with it off, to see if it detects any exhaust fumes. It should not.
innzane's comment may sound odd to some, but it's accurate. We use antifreeze because it boils at a high temperature than water. Why does it boil at a higher temperature? Because antifreeze has lower vapor pressure than water. And lower vapor pressure means less pressure inside our car's coolant system & radiator.
FLStype
11-03-2015 05:46 PM
FS[MidAtlantic]: XK8 A/C pressure line with switch
deelli
10-22-2015 11:19 PM
