Own a Jaguar 2004 X-Type with 95,000 miles and need an ABS Module Engine Light
My Jaguar X-Type has recently been popping up with sensor codes. I'vd had it run and For the most part they say the ABS module needs to be replaced. I have a local mechanic that can fix it but I don't want to spend thousands to do that since it isn't essential except for in the winter time and certain weather conditions.
Any suggestions on how and where to start to purchase an ABS module? I have a mechanic who could do the work. Any suggestions would be greatly appreciated.
Some other codes after being run are
C1145 - Wheel speed
P1260 - Security Input
P1582 - Flight Recorder is stored
P1629 - Gen. Front Right Tire Failure
P1632 - Gen. Charge System Failure
P0706 - Trans Range sensor circuit
C1145 - Wheel speed
Received 3,887 Likes
Ireedy, I would first start with looking at the wheel speed sensor. That is the more likely cause of what you are seeing than the ABS module. But then, with the array of codes that you are getting, I would have the battery looked at before anything else and see what the condition of the battery is. Having a battery that is weak will cause the computers to toss strange codes and give you the symptoms that you are seeing. The price of a battery is much less than that of an ABS module.
lreedyjones (09-10-2013)
FS[SouthEast]: 2005 Jaguar XKR Convertible Supercharged
divingmom
08-25-2015 07:54 PM
