Oxygen Sensor location
Hows eveyone doing and happy new year,
i have 2002 xtype 3.0 and pulled the code PO0057 which is oxygen sensor low circuit. It states bank two sensor two. Which of the four oxygen sensors is this as i face the engine? front of engine sensors or rear sensors? left side or right side.
Does anyone have information on the Walker aftermarket O2 sensor? Do they work and improve performance or are you better off just buying a stock product?? Can someone put a diagram of all the O2 sensors and how many wires each one is too. Thanks.
$180.00 ouch!!! Does it work?????[/align][/align]2002-2005 Jaguar X-Type - Walker Products After Cat. Left Oxygen Sensor - 4 Wire [/align][/align]Part Number: 25024439[/align]OXYGEN SENSOR, 4 WIRE, DIRECT FIT REPLACEMENT PART, LEFT, AFTER CATALYTIC CONVERTER -- Improve Your Cars Engine Response, Gas Mileage And Lower Its Emissions When You Replace Its Tired Old Oxygen Sensor, Exceeds OEM Specifications And Test Requirements, Original Equipment Part # C2C1238
![](http://www.autopartswarehouse.com/images/product_images/logos/walker-products.gif)
![](http://www.autopartswarehouse.com/images/product_images/thumbs200/walker_products/250-24439.jpg)
moxie (08-19-2014)
i have 2002 xtype 3.0 primium package and it has 68,000 miles on it. from jag i have a buddy that works thier original price list is 180 each. I get a hook up ten over cost which is 140. Every little bit helps.
PS is is after the crazy curse of the xtype bad transmission gearbox failure. I was lucky and bought the extended warrenty which the total cost of the new transmission install was 5,200 dollars. i did not pay a dime. so be weary of little slips here and there thats all the warning i had. Then one day cruizing on the highway at 75 mph roms just went out and instument told me i had gearbox failure i was like no **** when the rpm's went to 5 thousand rpms. So we will see what happens next.
installed HID's yesterday unbelievable how easy it was
take care and this site is the best i seen glad i ran into it
Received 9,011 Likes
![Name: T15ESSJAG5.jpg
Size: 6.3 KB](https://www.jaguarforums.com/forum/attachments/x-type-x400-14/194372d1501334017-oxygen-sensor-location-t15essjag5.jpg)
![Name: X6JYMSAAB5.jpg
Size: 6.1 KB](https://www.jaguarforums.com/forum/attachments/x-type-x400-14/194373d1501334017-oxygen-sensor-location-x6jymsaab5.jpg)
![Name: AudiX6JYM-2.jpg
Size: 6.4 KB](https://www.jaguarforums.com/forum/attachments/x-type-x400-14/194374d1501334017-oxygen-sensor-location-audix6jym-2.jpg)
ORIGINAL: morales8416
Sounds like you had a few problems got them sorted under warranty and had a lucky escape.... Nice post.
Glad you like the forum and hope to see more of you
Jim
KarimPA
09-03-2015 07:32 PM
