Oxygen Sensor part numbers
Received 3,887 Likes
Spike, why even go to the dealership to get the parts. The O2 sensors are made by Denso and are re-labeled with the Ford/Jag numbers.
The upstream sensor is a Denso 234-9029. The downstream sensor is a Denso 234-4798. Keep in mind that the downstream sensors are called oxygen sensors and the upstream ones are sometimes referred to as air-to-fuel mixture sensors, but may also be referred to as oxygen sensors too. From there, you can walk into any auto parts store and order it that way.
Thanks for your reply. Replacing all 4 at the same time is probably a good idea right? I have no CEL on but as I hVe posted many times, I have an occasional "heaviness" and high fuel consumption. It has been recommended enough at this point that I want to eliminate these as a possibility.
Did you change your own?
All all four easily accessible ?
Thanks !!!!
Thanks !!!!
Spike, do you need to change all 4, I say no. Should you replace both uppers or both lowers, yes. That way you don't have build up on 1 sensor and a band new one on the other side.
As for accessibility, the lowers are pretty easy to get to as I recall as you simply get under the car and they are just in front of the Y-Pipe. The sensor on the front of the engine (between engine and radiator) is fairly easy to get to once you remove the air filter box. Now, the one on the back of the engine is a PITA. Some members have gone from the bottom and had to stick their hands up between the drive shaft and exhaust and in general fought to get their hands to the needed areas. Option 2 is to remove the intake manifold off of the car and then go in from the top (this is the option I am planning on taking). More items to remove, but seems easier and quicker to do in the long run.
KarimPA
09-12-2015 08:15 AM
KarimPA
09-03-2015 07:32 PM
innzane
09-02-2015 10:08 AM
