P0171 & p0172
![Question](https://www.jaguarforums.com/forum/images/icons/icon5.gif)
Please need help with this codes,recently my car have this codes and i read all about them. replace the olds o-rings with a leak (I put new greens),new air filter,fuel filter, not leak on the breath hose,clean the MAF and nothing some ideas ?? i hear something of the egr valve but not sure location.
2002 jaguar x type 2.5
ooohhh and my rear left look a positive camber,I check the whole thing with some bushing wear.need replace lower arm? some ideas.
Had somthing simular problem. check the vacume line fron the master break cylinder to the intake manifold they can crack on the under side . The round valve in the middle of this line [ cant remember the correct name ] can also crack on the underside check it also . when you put the new green o rings in the IMT control valves check to see there seated and not still leaking.
Cadillac (01-07-2012)
I solved the problem, I only reset the codes and run like 15 highway miles and my light never come back,now I have new Texas sticker. Now my problem is a positive camber on my rear left wheel, it have positive camber wear I know some bushings are worn but I don't know if need replace all the wear pieces or something.
Skippy99 thanks for the tip.
sounds like you have a simular problem as me with the rear suspension worn inner edge of rear tires . My was caused by worn lower control arm looks like a wish bone and there is one on each side of the car.Part Number is C2S50863 it is a lateral control arm they seize up or the bushings ware out up here in canada they seize from rust ansd salt . you will need a rear wheel alinement after you replace any parts . Good luck
clubairth1
29
05-10-2024 12:57 PM
Bob Gelston
09-14-2015 11:08 PM
