P0171, p0174, p1111
P0171, p0174, p1111
Ok, I know over the last year I've seen these numbers, but of course when you need the information on them, you can never find them quick enough, even if you do there not always where you want to be. So I started a new thread.
Here's where I'm at, just like everyone else all of a sudden, the cars been running great for the past year. So, I know that with my reader bank 1 & 2 are running lean. I checked for a crack in any of my vacum lines that I could see found none, I'm thinking intake gasket or O-rings a good possible problem. Which will be a good time to change those rear plugs at the same time. It's not something that is going on all the time. Yesterday, problem started, I went to Autozone (I had an old reader that didn't work), they read the codes, and reset. I ran the car 450 miles, not once did anything change, the car ran great. Stopped a couple of places, and no light no problem with the cold weather and snow, ran great. Came home, put the car in the garage. This morning, went to do some shopping, got 200 yards down the road and light came on, went some 45 miles round trip, bought a new reader. It gave me the same readings, can't figure if it's a vacum leak causeing the lean fuel problem, if it was I think it would be happening all the time and it's not. So, now I'm thinking more on the fuel injectors haveing a problem. I have put in some injector cleaner in the last couple months, and my milage has come up. Could I have caused a problem, shifting some dirt around? But the P1111, has me, (no DTC found, see manual). what's DTC I should know this but it's not coming to me. I haven't looked it up yet, I know there's a lot of good guys in here and I'm interested in all comments and suggestions
Got the P1000
Yes I did get the P1000, it was jusst the P1111 code came through, new reader. My old one was out dated and wouldn't read my x-type. So just getting use to the new one. I got a Actron, auto scanner, nice scanner just getting use to it.
Just use this thread to find any other codes that come up: https://www.jaguarforums.com/forum/s...ad.php?t=18395
P1000 OBD Systems Readiness Test Not Complete
P1111 System Pass
P1111 System Pass
When you get the P1111 STOP ERASING/CLEARING THE CODE!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
P1111 is a GOOD THING!!!!!
Clear the DTC P1111 and you will get P 1000
You have to start all over again!!!!!!!!!!!!!!!!!
YOU CAN ONLY HAVE ONE OR THE OTHER!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!
bob gauff
bob gauff
The IMT o-rings, are they where the brake booster line goes into the intake manifold and the other one is over by the front of the intake?
The IMT's are the two black circular pieces you see when you look down at the intake while facing the car from the passenger side fender. easy to unbolt the upper one to see what you have for an o-ring. Yellow is no good. Green means it's got the updated one.
Do a quick search in the X-type section and there will be pictures.
vai1953 (12-15-2010)
I checked my IMT O-rings and they are yellow, so I guess I have to get the green one's. Do they come in the intake gasket Kit or do I have to get them from the dealer? I wonder if Ford might carry them, The closest Jaguar dealer to me is like 60 or so miles away. Any one that has changed them, could you let me know where you got yours, Thanks
Also, the 2 little black vacuum lines that are on the intake manifold, do they have o-rings on them and do they just pull out or is there a way they come out with out breaking them. I would think that after those plastic pieces sitting in that hot manifold all that time, they would become brittle. Any suggestions?
https://www.jaguarforums.com/forum/s...ad.php?t=46744
As far as the vacuum lines that attach at the intake, the collar that is in there needs to be pushed down as you pull the line out.
So then this site if full of crap when it comes to codes? http://www.obd-codes.com/trouble_codes/jaguar/
vai1953 (12-16-2010)
Motorcarman, my problem seems to be intermitent. I can clear the codes except P1111 and the car runs great for a couple hundred miles, the only other thing I can see is that the milage is lower than it use to be. I can't really see it being a vacuum leak, cause it don't happen all the time, and the car still runs great. any ideas?
I am attaching the OBD II chart for your car. I am also going to provide a link to a troubleshooting procedure that works for most cars and should work fine for yours. I recently had to chase down a leak (P0171 & P0174) and used Throttle Body cleaner and would spray it until the engine began shacking telling me I was spraying in the right place. When you look up the P0171 & P0174 you will see that they are related to a vacuum leak most of time. As noted it could also be related to MAFS that can be cleaned to a host of other things. Look at the possible cause and eliminate the simple and work your way to the others. Note: Along with the “O” rings I understand the vacuum hose to the brake seems to develop leaks. I hope others that know the X-Type will chime in.
http://www.gusglikas.com/images/Auto...otos/P0171.pdf
Gus, I have Autozone on my speed dail..LOL But I called Autozone & NAPA, I would think with the O-rings they have enough in stock that I could go and match them up and install them, NAPA had the intake gasket, but Autozone didn't. I just figured if the o-ring were a update it might be a good idea to get them from the dealer and while I was there get the gasket too. I have a 02 x-type, and I know they can be a little tempermental, so I'm trying to keep it happy...LOL
