P0174 code
Ok Ive done the search and read and tryed many different things but still getting the code poping up, 02 xtype 3.0 auto, after reseting the code, I can drive forever and not get the CEL and cruise not avalible, but after I shut it off and then restart and drive about 5 miles they come back on, but only after the car has been shut off, any ideas ??
changed
fuel filter
maf sensor
airfilter
checked for vac leaks ( found none )
changed
fuel filter
maf sensor
airfilter
Just to make sure you checked all your vacuum leaks:
Link:
jaghelp.com: Jaguar X-type common vacuum leaks. P0171 and P0174
Also there is a vacuum hose that is right below the manifold behind the throttle body that causes the P0171 and not the P0174. I usually take out the throttle body to fix this hose, just a bit of RTV sylicon.
Link:
Received 6,320 Likes
clubairth1
29
05-10-2024 12:57 PM
OkieTim
09-08-2015 04:48 PM
