P0191 , car dies shortly afterwards
heres the tool you can use
https://www.amazon.com/Fuel-Pump-Lock-Ring-Removal/dp/B01JY5VZZU/ref=sr_1_1_sspa?keywords=fuel+pump+tool&qid=1565309701&s=gateway&sr=8-1-spons&psc=1&spLa=ZW5jcnlwdGVkUXVhbGlmaWVyPUEzRkM2M0FYQTZFTUNSJmVuY3J5cHRlZElkPUEwMDc0NDgyMkxNVU9KQVBIU0pNUSZlbmNyeXB0ZWRBZElkPUEwODQwOTIxMlQzQVhST0dNV1UyOSZ3aWRnZXROYW1lPXNwX2F0ZiZhY3Rpb249Y2xpY2tSZWRpcmVjdCZkb05vdExvZ0NsaWNrPXRydWU=
Sealed up the hole with aluminum tape, replaced everything and detailed the car. Went on a 120 mile uninterrupted drive on the highway and no odors, no lights and no problems. hopefully this means everything went well, will remain so, and my car is ready for my 300 mile trip. Thanks everyone for your input and help. This ended up costing 40 dollars for thE brand new OEM internal Motorcraft pump + 10 for a small triangular metal file to score and notch the brass pipe of said new pump + 20 for generic lock ring remover + about 15 for the aluminum tape. Plus whatever the cost of the new o ring gasket was.
Thanks again
Thanks again
Cbenbrook (08-10-2019)
I think if using just the pump only, a double (does single and double) flare tool would be helpful for the different fuel hook up on the replacement pump. Not awfully costly, usually a bit over $20 USD.
Advance has a basic one for like 5 bucks
Thanks again
Thanks again
1320racer
08-24-2016 12:42 PM
Chris718
11-23-2013 08:35 PM
