P0191 , car dies shortly afterwards
Old 08-08-2019, 07:06 PM
dennis black's Avatar
you may get a p0455 code saying theres a leak or you maybe ok ....just drive and if theres no code or gas smell your fine
Old 08-08-2019, 07:15 PM
Old 08-08-2019, 08:10 PM
Spikepaga's Avatar
Originally Posted by dennis black
Thanks Dennis- that sure does look better than the generic one I bought at the auto parts store!!
I was able to further secure it. Not sure if it was tighter originally, but it’s pretty close now
Old 08-10-2019, 08:49 AM
Spikepaga's Avatar
Sealed up the hole with aluminum tape, replaced everything and detailed the car. Went on a 120 mile uninterrupted drive on the highway and no odors, no lights and no problems. hopefully this means everything went well, will remain so, and my car is ready for my 300 mile trip. Thanks everyone for your input and help. This ended up costing 40 dollars for thE brand new OEM internal Motorcraft pump + 10 for a small triangular metal file to score and notch the brass pipe of said new pump + 20 for generic lock ring remover + about 15 for the aluminum tape. Plus whatever the cost of the new o ring gasket was.
Thanks again
Cbenbrook (08-10-2019)
Old 08-10-2019, 09:34 PM
Dell Gailey's Avatar
I think if using just the pump only, a double (does single and double) flare tool would be helpful for the different fuel hook up on the replacement pump. Not awfully costly, usually a bit over $20 USD.
Advance has a basic one for like 5 bucks
Old 09-03-2019, 11:05 AM
Spikepaga's Avatar
Thanks again
The new 40 dollar OEM Motorcraft internal pump went on the 6 hour 300 mile trip (each way) with no problem at all. My biggest fear was that the rubber fuel hose was going to slip from the brass pipe of the new pump since the original pump has a nipple on said brass pipe, but scoring it and making a notch worked perfectly. Thanks all for your help
Qvhk
01-24-2023 02:13 PM
1320racer
08-24-2016 12:42 PM
Chris718
11-23-2013 08:35 PM
yjmcb
05-22-2009 07:49 AM
timxtype02
03-12-2008 06:17 AM
Quick Reply: P0191 , car dies shortly afterwards
