P0333 Knock Sensor replacement project - advice appreciated
Well, been getting this P0333 code for a few weeks and keeps coming back even when the codes are cleared. Car appears to keep going into limp mode (stutters when trying to go above 3000 RPM but runs smooth otherwise, is this limp mode?).
So, I'm planning on tackling this repair this weekend. Knock sensor has been ordered, but I want to run a parts list by everyone and most importantly, can I get this stuff listed below at local auto stores?
Here's what I'm planning on doing while I'm in there under the intakes:
-update ribbed pcv breather hose (already replaced)
-upper and lower intake plenum gasket/seals (6 of each)
-spark plugs (any recommended plugs I should use?)
-new pcv valve
-throttle body gasket (should I take it off the intake?)
-new o-ring for the water neck side
-new seal for the water pump side
Can anyone weigh in on some good places that they've bought these items for their x-type?
I am reading stshots great walkthrough of his same repair. Any other encouragement or tips?
-new pcv valve
Yes, I plan on taking pictures throughout the process and will post a good write-up as it took me a lot of research to figure out how to do it.
As for the updated PCV hose, here is where I bought it:
Breather Hose - Jaguar Parts and Land Rover Parts
C2S40863
BREATHER HOSE
$13.11
C2S40863
BREATHER HOSE
$13.11
BrentGardner
28
04-26-2024 03:08 AM
Tony K
03-26-2024 01:53 PM
Doberman_Fan
22
12-24-2019 06:21 AM
X_Type_South_Africa
12-09-2015 05:37 PM
FS[Central US]: 1999 XJ8 Parts or project car for sale Lawrence, KS
casepie
08-30-2015 09:49 PM
