P0430 after several repairs
So here's what is new on the car:
-New spark plugs (autolite platinums gapped at 0.050")
-New upper and lower intake seals
-New PCV and upgraded hose
-New front Cat (Benchmark direct fit 49 state legal)
Raped twice for "diagnostic" by the dealer, providing no additional insight.
84k on the car, it keeps throwing the code. I'm tempted to replace the downstream front O2 sensor, but wanted to get you guys opinions first.
I originally had the P0430, replaced the cat, then had a BUNCH of misfire and rough idle codes, so I replaced the seals and plugs. Those all went away, but I'm still getting the P0430.
rf69 (01-11-2012)
Called Advance and Autzone- $93 for a sensor, $57 for a universal I have to wire up. Hmmm.
It was worth it to me to buy the OE's. At least that way you can rule out the O2 once replaced and not worry that it may still be the problem afterward thinking "did I wire it right?"
My two cents.
Guest
Posts: n/a
hello so i got the p0430 code on my 2003 jag took it to a regular mecahnic shop and the only thing they can say it may be the catalytic converted most likely bank 2? he also said that it will be fine to run it like that till I decide to replace it or not so ive been driving with the engine light for like 2 weeks with no major problems til this mornig that the car went to limp home mode can that be related to the cat as well or do i have a major problem does annyone got the same isue?
So update....
New upstream and downstream o2 sensors, obviously the cat is new (Benchmark 49-state legal). My P0430 returned. Any ideas?
Again here is my new parts list:
-Front cat
-Front o2 sensors UP and DOWN
-spark plugs (autolite platinums for what its worth)
-upper and lower intake manifold gaskets
-gen 2 pvc hose w/ new pvc
-Front cat
I get this same code when driving on the highway on cold days. It goes away by itself once the weather warms up, but it's annoying.
The dealer can possibly reprogram your car's "computer" with updated software that has looser threshold values. My guess is that the efficiency of the cat is ok, but the detection is too strict and throws P0430 even though it works within acceptable parameters. At any rate, I'm curious to see what you find.
Received 2,192 Likes
rf69 (01-11-2012)
I just did this to the rear ds sensor on my car today. No threading problems. The non-foulers were part #42002 dorman "help" brand that I got at Oriely auto that are 18mm short tapered. I cleared my code (P0420) and will report back if mine worked or not. Marc, I'm surprised yours didn't fit. I can't imagine the front and rear cats would have different threads but maybe they do.
rf69 (01-11-2012)
I finnally bit the bullet and fixed my P0430. I tried the O2 sensors myself at 200.00 for the pair. I eventually took it to the shop where it was determined to be the Catalytic converter Bank 2
1 Cat 760.00
5 hrs 375.00
2 Gaskets 30.82
3 nuts 17.85
Enviro/cleaner 15.00
Tax 56.01
Total 1260.76
Believe it or not I got the dealer who I purchased the car used from over a month ago to cover the cost. I have to say i was very surprised. No cel and she is running great.
1 Cat 760.00
5 hrs 375.00
2 Gaskets 30.82
3 nuts 17.85
Tax 56.01
Total 1260.76
